Manual HVAC Question
Old Feb 13, 2016 | 01:01 PM
LannyL81's Avatar
Default Manual HVAC Question
On the manual HVAC system, with the controller at the OFF position I still get air flow from dash and floor vents, the temperature of which varies with the temp control.
Was wondering if this is normal or not. I would think that OFF means OFF, but perhaps not. If not normal, then suggestions as to where to look.
I have already checked the white lever above the transmission hump and nothing broken there. Both vacuum actuators appear to be working correctly.
Appreciate any comments....well...maybe not all comments.....LOL...
Old Feb 13, 2016 | 03:46 PM
Normal. With the mode switch in the OFF position, no voltage is supplied to the blower switch, and all of the actuators go to their default position, (floor and dash). When the vehicle is in motion, air entering the cowl will be moved through the ducts, and yes, you can feel it. If you open a window, you will feel it even more. Temperature can be adjusted regardless of mode or fan position.
Old Feb 13, 2016 | 04:53 PM
RQuickDraw's Avatar
RQuickDraw is on a distinguished road
Lanny, I have often wondered about this same thing. It's nice to know it is normal. Thanks, Captain.
Old Feb 13, 2016 | 07:08 PM
LannyL81's Avatar
Normal is a good thing....thank you once again Captain.
specialty8
29
Jan 24, 2023 10:35 AM
smartieab
Dec 20, 2014 07:40 AM
specialty8
Nov 2, 2013 06:27 PM
kota04sxt
Dec 10, 2009 09:34 PM
blazin_j
Oct 7, 2009 08:25 AM
