MAP sensor location 4.3L 2005 blazer
Old Mar 30, 2021 | 02:53 PM
GeorgeLG's Avatar
I would first check the output of your TPS. Engine off, live data on your ODBII scanner look at the TPS values as you go from the idle position to full throttle and back.
Next up is check for vacuum leaks, let me know if you need help.
Next is to figure out if you have actual misfires going on (you can start with the article in my signature). Are there and cylinders showing misfires when the engine runs crappy?
You can start it in the dark and mist all the ignition components to look for arcing.
Have you done the fuel pressure tests in the sticky?
George
stephen5217
Feb 17, 2022 10:07 AM
Nickydenver
Aug 4, 2018 10:51 AM
gtmccormick
Feb 16, 2013 08:06 PM
slash3359
Jul 18, 2012 05:01 PM
krazii
Jul 27, 2011 12:51 PM
