Mass airflow throwing code
Old Jun 22, 2009 | 02:36 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default Mass airflow throwing code
Where's a good place to pick up a replacement? Probably not worth buying new, right?
Old Jun 22, 2009 | 03:25 PM
Being a relatively fragile, new would be the best if you can swing it. Nothing worse than buying a used replacement only to find it did not work.
But try cleaning it first.
Old Jun 22, 2009 | 05:16 PM
hrmmm, good point.
yeah, I'd thought about cleaning it ... probably should get a new filter in there too.
thanks as always for the input.
Old Jun 22, 2009 | 09:10 PM
Let us know!
Old Jun 25, 2009 | 04:04 AM
Exclamation
Let us know!
bwahahaha ... apparently at some point some rodent made a home of my intake. the old filter was partially crushed from the external air side, and it was LOADED with the remains of sunflower seed shells -- every single rib of the filter. I couldn't believe how many I shook out of there -- and there were still more falling out every time I flexed it.
The MAS itself looked good, but I sprayed it down anyhow. Throttle response and acceleration seem MUCH improved, going to clear codes at Advance Auto sometime today and see if I'm still getting MAS, O2 and small leak messages. (Already replaced the fuel cap, didn't do any good on the leak code ...)
Old Jun 25, 2009 | 03:52 PM
SES light went off on its own. Acceleration has returned. And I can hear the truck sucking air at low RPM again ... though some of that noise may have been obscured by a bad bearing I replaced earlier this week, and not a reduction in airflow ... it's a toss-up.
idezire
Nov 3, 2011 05:31 PM
ZR 2
Jun 23, 2008 01:57 PM
EuroGoldLS
Headers, Intake, & Exhaust
Mar 25, 2007 01:33 PM
ilikebread
21
Mar 29, 2006 11:30 PM
BlaZeR FXB1581
Nov 13, 2005 03:41 PM
