Massive problem under dash
Old Dec 24, 2014 | 11:02 AM
mattjphoto's Avatar
mattjphoto is on a distinguished road
Default Massive problem under dash
I found my problem. I have no clue how to even get to that broken white part. This
is suppose to attached to this broken white part
Attached Thumbnails Massive problem under dash-423a1451-6f2e-49f1-a264-5b0acbf632ac_zpsq7s623sm.jpg   Massive problem under dash-780699ba-d0cc-4689-affa-1386854ae216_zps5ju0ysbw.jpg
Old Dec 24, 2014 | 03:48 PM
LannyL81's Avatar
I believe the vacuum actuator in your hand is for the RECIR / FRESH air door. Not able to see in your 2nd picture the blend door actuator motor....did you remove it?
Only way I know of to fix this is to remove the dash and then you can take the air box apart to access the door.
Taking the dash out is not all that difficult, just requires taking notes as to which bolts/screws go where. The dash will rotate on pins on each side and you just lift it off and out. Best to have another set of hands as it is a bit awkard getting across the seats while holding the dash. Everything unplugs.
Old Dec 25, 2014 | 08:43 PM
mattjphoto's Avatar
The blend door actuator hasn't been removed. Its up there in the top right of the photo. The middle left white thing I can move and it does move some type of door. I assume I safe to drive w/ that broken for now?
Old Dec 26, 2014 | 08:51 AM
LannyL81's Avatar
Okay...think I see the blend door actuator now.
Yep, safe to drive. I suggest taping the white thing in place, either in the RECIR or FRESH position...probably RECIR for Winter...although at this moment I am not sure which position is which. I guess you could make the selection on the HVAC panel for one or the other and note what the vacuum actuator does to determine which position is which.
Later
94psBlazer
Mar 23, 2015 09:32 PM
s10blazer20
Jan 27, 2011 04:38 PM
dcshoes1
Aug 6, 2009 01:20 AM
Tippman7641
May 24, 2008 02:50 AM
avorg
Mar 15, 2008 11:52 PM
