Me SO Horny (Not Really - No Horn!)
Hey All,
My 1995 Blazer LT twodoor 4X4 has exhibited one of it's latest "quirks".
My horn as begun to only work sometimes (like not working when I need it!)
The horn button is running off a switch on the dash (Hillbilly indeed but the previous owner didn't have the factory tool to replace the horn contact spring under the airbag, so the horn was wired to a button on the dash.
When the horn "declines to function" (Ie quits working) I've tried crossing the contacts to complete the circuit to ensure the switch is not the problem.
What problem areas should I give examination?
Where exactly IS the horn located on an S-10 blazer so I can check the contacts and wires?
Thanks All for your help!
BIGGER_HAMMER
BIGGER_HAMMER
I've figured out where the two horns are located (inside the inner fender behind the battery and the windshield washer resevoir tanks.
I'm going to check the relay under the dash too (
Thanks
BIGGER_HAMMER
Thanks
BIGGER_HAMMER
dualemg81
Mar 23, 2010 06:30 AM
pinetopfirefighter
Mar 24, 2007 04:36 PM
