metric or SAE
Old Nov 1, 2008 | 03:55 AM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default metric or SAE
Are these trucks metric or SAE? 2001+ in particular ... thanks in advance.
Old Nov 1, 2008 | 06:59 AM
salvy's Avatar
salvy is an unknown quantity at this point
Default RE: metric or SAE
They're mixed (both)
Old Nov 1, 2008 | 07:07 AM
What are the most commonly used standard sizes? I have a pretty complete metric set ...
I need to check the vac lines for 4WD issues today, any idea what the bolts on the battery tray are offhand?
Old Nov 1, 2008 | 07:22 AM
salvy's Avatar
metric I believe
Old Nov 1, 2008 | 08:18 AM
Yep, mostly metric.
Old Nov 1, 2008 | 08:57 AM
mysons95's Avatar
mysons95 is an unknown quantity at this point
I just use metric on most things since they increase in size by only 1 millimeter for each wrench.
They work fine for most US standard applications unless you are really putting some tork on a rusty bolt in US standard...then the standard wrenches work better.
Old Nov 1, 2008 | 09:10 AM
WolfPack's Avatar
I feel like everything I do on the blazer, I'm always having to use the 15mm socket...which always seem to escape after the first bolt comes out[:@]
Old Nov 1, 2008 | 09:29 AM
mysons95's Avatar
Yeah, this is how they line up...
US Metric
1/2" 13mm
9/16" 14mm
5/8" 16mm
11/16" 17mm
Old Nov 1, 2008 | 10:23 AM
thanks all
Old Nov 2, 2008 | 10:02 AM
WolfPack's Avatar
Using a 13mm socket on a 1/2' bolt head is a good way to round it off [&o]
