Might be a dumb question here be warned. Hearing a sound like water gushing?
Old Mar 28, 2013 | 11:27 PM
James Honey's Avatar
James Honey is on a distinguished road
Default Might be a dumb question here be warned. Hearing a sound like water gushing?
Yea I don't know this is probably a really stupid question to ask but here it goes anyway. What would make a sound like water gushing or water moving around when ever my rpm goes above 3k? I hear that noise while I am inside driving down there road taking of from a stop or if I just rev it up some. Sounds like the noise is coming from behind my dash somewhere. Anything to be concerned about? Is is something to do with the heater core?
Old Mar 28, 2013 | 11:44 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
partially plugged heater core? getting flow at high rpms? ive had that before.
flush or recore, but first check coolant level
Old Mar 29, 2013 | 09:06 AM
chris015's Avatar
its in the heatercore. Usually just low in coolant. Top off your coolant in the reservoir and radiator when she cools down. See if that fixes it. if not,backflush your heatercore. Your core isnt bad per say,just clogged with some gum from the years of service. you can sometimes get lucky and backflush em and clean them out. Or you might get lucky and it be low in coolant.
Old Mar 29, 2013 | 07:31 PM
You guys are spot on, I can't believe I forgot to even check the coolant level. I looked tonight and the radiator is low and the reservoir is empty. I will buy some anti-freeze and fill it up. It had been making this noise for a while. I hope there is nothing wrong with it why the radiator is low and the reservoir is empty. Will keep you guys in the loop.
Old Mar 29, 2013 | 07:55 PM
tibby's Avatar
Default .
Same thing happened to me awhile back. I heard the rushing water sound and checked the coolant levels and they were low. Turned out, I had a coolant leak. Since I have a full skid plate set underneath, it was hard to spot at first until the leak worsened. Once it worsened, it would finally leak off the skid plate and make a puddle on the ground.
Old Apr 5, 2013 | 10:40 PM
Still making that sound I will have to flush the heater core next and see.
Old Apr 6, 2013 | 01:00 AM
Manatee's Avatar
Manatee is on a distinguished road
Mine made that noise because the core was leaking and there was air in the system. I had previously flushed the core because it was clogged and no circulation/ no heat. If the carpet on the right side under the heater is wet, it is probably a leak.
Old Apr 16, 2013 | 09:35 PM
x33camaro's Avatar
x33camaro is an unknown quantity at this point
I agree with Manatee, check the carpet. I will be replacing the heater core this weekend. Make sure to buy a GM one. Don't go cheap or you will replace it twice.
Old Apr 16, 2013 | 10:58 PM
Spree's Avatar
Spree is on a distinguished road
The carpet doe's not allway's get wet when the heater core is leaking! Mine never did. I could smell it, the window would fog up, but no wet carpet, and my coolant was never low, but I did hear the water sound behind the dash.
Old Apr 17, 2013 | 03:51 PM
Prom's Avatar
Prom is on a distinguished road
I had a blown heater core with coolant pouring out of it. Never came inside. If its not leaking anywhere I would watch the levels and let it gurgle, that heater core is not an enjoyable fix.
kmartin
Sep 13, 2012 11:09 AM
dano440
Jun 11, 2012 06:59 AM
chris015
Apr 28, 2009 11:29 PM
epitaphoftwilight
Apr 5, 2007 03:18 AM
vdog
Jan 10, 2007 04:46 PM
