hearing water in from the front of my vehicle
Old Sep 13, 2012 | 06:51 AM
kmartin's Avatar
kmartin is an unknown quantity at this point
Default hearing water in from the front of my vehicle
I have a 2003 Chevy Blazer. When I drive I hear water, seems the sound is coming from the front of the vehicle, mainly on the passenger side. I looked under the vehicle to see if there is any clogged drains, but couldn't find a drain. Tryed to look into the cowl area and appeared dry. This is driving nuts. Any insights would be helpful.
Old Sep 13, 2012 | 08:34 AM
jeffintoronto's Avatar
jeffintoronto is an unknown quantity at this point
It's your heater core.
It's either gunked up with sludge and/or you have air trapped in your cooling system.
https://blazerforum.com/forum/tech-a...e-flush-51751/
Old Sep 13, 2012 | 08:41 AM
warthogdriver's Avatar
Yes....heater core is the cause. If you fill the system and the noise comes back you have leak somewhere in your system....rad cap...hose leak....core going bad.
Old Sep 13, 2012 | 10:18 AM
kmartin's Avatar
I check the heat yesterday. The heat coming out of the vent was very hot. So yes I have heat, plenty of it. So my other guess is air in the system. Could it be possible that coolant is leaking out and being contained?
Old Sep 13, 2012 | 11:09 AM
rexmburns's Avatar
Super Moderator
You have air in the system! Like was explained in your other thread concerning this issue you need to get the air out of the cooling system and the noise you are hearing will go away. It has happened to me three times after flushing my system and it just takes patience to let it run and flush all of the air out in the way it was explained by chcknugget on your other thread. Go do that and you will be done with this issue!!
Just so everyone knows which thread I'm refering to https://blazerforum.com/forum/2nd-ge...ld-i-do-73420/
James Honey
Apr 17, 2013 03:51 PM
ChrisMN
Nov 10, 2012 03:24 AM
99Legendary
Apr 24, 2012 09:02 AM
Kai
Headers, Intake, & Exhaust
31
Nov 4, 2010 04:21 PM
yazan84
Dec 29, 2007 11:38 PM
