is mileage stored on IPC or CPU?? 99 blazer
Old May 3, 2008 | 12:03 PM
rwrows's Avatar
rwrows is an unknown quantity at this point
Default is mileage stored on IPC or CPU?? 99 blazer
any one know if the mileage of a 99 blazer is stored on the internal computer or is it stored on the guage cluster? thanks.
Old May 3, 2008 | 12:44 PM
TripleBlackBlazer's Avatar
Default RE: is mileage stored on IPC or CPU?? 99 blazer
My gut says it's stored on the actual cluster because sellers like s10warehouse on eBay list the mileage of the clusters. Also I have read in other threads that if you replace your cluster you need to file with the DMV to denote that your truck has altered mileage.
Old May 3, 2008 | 12:53 PM
It actually is both (pcm and cluster). Only a dealer can set the correct mileage in most cases, but some cases, even they cannot set the proper mileage. New service parts will be coded to accept the mileage programming. Used parts may not be able to be set. The IPC displays its stored mileage until programmed to match the PCM.
It actually isn't that bad to file for a mileage deviation through your dmv. Shows up on your title so there shouldn't be any confusion.
Old May 4, 2008 | 08:57 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
It depends on the vehicle we had a car that the cluster went weird so we got a used cluster that supposedly had78000 on it but our car only had 45000 when we plugged it in it showed the proper mileage for the car.
BlazerGirl2002
Jul 19, 2010 12:25 AM
rwrows
Apr 30, 2008 01:56 PM
drwalker88
Feb 16, 2007 01:18 AM
djbass_mekanik
Engine & Internal
Sep 20, 2006 12:49 AM
reggie4828
Engine & Internal
Jan 6, 2005 10:58 PM
