Misfires at light throttle
Old Apr 3, 2013 | 03:31 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Default Misfires at light throttle
I recently did LIM and the upper intake gaskets, It seems like right when I start from a stop the truck stumbles a bit! Also at highway speed at low RPM and a slight hill right before it seems the need to downshift it misses so bad once it made the CEL Light flash.
New plugs and wires!
Old Apr 3, 2013 | 04:22 PM
If it didn't miss before you replaced the gaskets, I'd say camshaft retard is off, (it needs to be checked & adjusted when the distributor is reinstalled). There are a ton of things that can cause a misfire, but I'd start there.
Old Apr 3, 2013 | 07:52 PM
Joshs4x4's Avatar
Good call hook I scanned and showed 13* so it's off a tooth or two!
Old Apr 3, 2013 | 08:49 PM
Probably just needs adjustment. If it were off a tooth, cam retard would be ~27 degrees or more and P1345 would set.
Old Apr 3, 2013 | 09:29 PM
Joshs4x4's Avatar
How can it be adjusted I googled and came up with nothing.
Old Apr 3, 2013 | 09:33 PM
Loosen the 10mm distributor hold down bolt and turn the distributor. Engine RPM must be snapped over 2K before taking the reading.
Old Apr 3, 2013 | 09:40 PM
Joshs4x4's Avatar
Okay cool easy! Hook you are awesome!
Old Apr 3, 2013 | 09:43 PM
If you can't get enough adjustment, you'll need to remove the original hold down bracket from the distributor and install one of these: Mr. Gasket 1009 Distributor Hold-Down Clamp Chrome Plated Incl. Bolt/Gasket Most auto parts stores have, or can get it. This will make the distributor fully adjustable.
EDIT: The chrome does not make the engine run better, it's the adjustment
Old Apr 3, 2013 | 09:50 PM
Joshs4x4's Avatar
But it is chrome so it adds 10hp
carlt1911
Mar 1, 2009 06:13 PM
agent305
13
Jun 4, 2008 10:24 AM
studentmechanic101
20
May 18, 2007 03:53 PM
darias
Apr 12, 2007 03:49 PM
Hanr3
17
Jan 25, 2007 12:57 AM
