Miss at idle when warm
Old Jun 24, 2008 | 09:47 PM
dardamar's Avatar
dardamar is an unknown quantity at this point
Default Miss at idle when warm
1996 S 10 Blazer LT. 195000 miles. The miss only happens at idle when the engine is good and hot. The miss is worse when the engine is under a load. ie. when parked at a stop light with the transmission in drive and the brake pressed. There is no miss when driving down the highway or street. Just at idle. No SES light on. New wires, plugs, cat converter, cam shaft sensor, crankshaft sensor, MAF sensor.10,000 miles ago. (I installed a new rebuilt engine 10,000 miles ago.)
Any idea what it is? The IAC? MAP sensor? EGR Valve? Any help appreciated.
Old Jun 25, 2008 | 06:35 AM
Default RE: Miss at idle when warm
A miss when hot points to the ICM (ignition control module). I would recommend that you have the ICM tested (Autozone or Advance Auto should be able to do it for free) and when they are testing it, have them repeat the test at least 10 times in rapid succession. This will heat up the ICM to operating temps and should reveal any faults that might not be apparent at lower temperatures.
Old Jun 25, 2008 | 09:46 PM
dardamar's Avatar
ok thanks for the response. how do you check the control module. Is it something that I can check??
Old Jun 26, 2008 | 06:31 AM
You have to load it. Hence why I suggested you go to Advance Auto or Autozone.
Old Jun 29, 2008 | 04:39 PM
dardamar's Avatar
The ignition control module checks out fine. Anyone have any other suggestion. Like I said in my first post it only does it at an idle when engine is hot, below 1000 RPM. It seems to be getting worse.
I have no codes stored. Could it be the idle air or the MAP sensor?
ussexplorer
Sep 27, 2013 03:38 PM
jrakers2
Mar 22, 2012 06:29 PM
trevorroe
Sep 21, 2009 10:25 PM
pokerface
Oct 20, 2007 01:39 PM
Inferno
Oct 22, 2006 08:56 PM
