Missing vacuum hose
Old Mar 24, 2013 | 06:10 PM
DeafTimberWolf's Avatar
DeafTimberWolf is on a distinguished road
Default Missing vacuum hose
Where does this hose suppose go to? See attachment. I need your help.
Old Mar 24, 2013 | 11:18 PM
AJBert's Avatar
Looks to me like you are missing the hose that goes to the accumulator in the wheel well.
Old Mar 24, 2013 | 11:26 PM
Thanks AJBert!
Old Mar 25, 2013 | 08:19 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
Thats to the vacuum ball. It isnt needed, if it's leaking vacuum just plug it.
Old Mar 26, 2013 | 12:34 PM
Ok Thanks
Old Mar 26, 2013 | 04:59 PM
The black side of the check valve goes to manifold vacuum. The 90 degree white fitting goes to the transfer case vacuum switch. The straight through white fitting goes to a Tee that should be dangling close by. On it there should be a short, (2") vacuum line that goes to another Tee. One side of the Tee goes to the vacuum reservoir in the left fender, just rearward of the ABS unit. The other side of the Tee goes to the HVAC system in the dash to operate the vacuum doors.
Old Mar 27, 2013 | 11:55 AM
Alright Thanks. I will check all hoses and replace the rotten hoses when weather gets warmer.
Old Jun 7, 2018 | 04:19 PM
lugnut41's Avatar
lugnut41 is on a distinguished road
Thanks to all you guys. Your photos and descriptions of the vacuum hoses also helped my problem. I had pulled the vacuum hose from the manifold to replace it and in doing so I pulled the hose to the accumulator tank off, I didn't know at the time what or where the hose went to as I could not see any connection. BUT reading you guys description and directions, plus the photo, I was able to find and reattach the hose.
love this forum
Thanks, Mel
Old Jun 7, 2018 | 05:01 PM
Zenith's Avatar
Zenith is on a distinguished road
love this forum
is an understatement
Cassera
22
Oct 12, 2019 09:07 PM
chevyragtopguy
Nov 11, 2015 09:38 PM
outsydthbox
20
Apr 14, 2011 07:25 PM
bobc997615
Mar 21, 2008 08:10 PM
bomber 1
Aug 31, 2005 10:10 PM
