Missing vacuum line
Old Jun 4, 2010 | 02:46 PM
davstarks's Avatar
davstarks is on a distinguished road
Default Missing vacuum line
I am missing the vacuum line that goes to the 4wd actuator under the battery. I need to know where the other end of the line connects so that I can run a new line. Any help would be appreciated, pics even more.
Old Jun 4, 2010 | 02:59 PM
nj4x4blaze's Avatar
It goes to the vaccuum switch located above the transfer case. If you look under your driver side where the transfer case is located, you will see 3 rubber hoses leading to the switch above the transfer case.
Old Jun 4, 2010 | 04:16 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
The size of the vacuum line (as was discussed on another thread) is 5/32" not 3/16". If you put too big of a hose on it will slow down the actuation time to engage the front axle. Here's the link for a little more info. Hope this helps.
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/96-blazer-4-whee-drive-vaccum-line-question-44845/
Old Jun 5, 2010 | 08:05 PM
davstarks's Avatar
Thanks guys, I appreciate the help.
McGyver
Mar 17, 2015 08:03 AM
wazzledoozle
Jun 4, 2011 05:14 PM
mikej502
Aug 5, 2009 04:39 PM
nsomnia_redline
15
Apr 29, 2009 08:37 AM
tesshin
Apr 28, 2007 03:12 PM
