multifunction switch
Old May 11, 2007 | 04:40 PM
northern 666's Avatar
northern 666 is an unknown quantity at this point
Default multifunction switch
Hi , I posted last night about air bag removal for changing mymultifunctionswitch.
As stated in a reply i did not have to remove it at all which was great.
My problem now is, I replaced the switch with an original GM switch but now i have a different problem.
Before my hazard lights and signals functioned correctly when truck running,but after signals were off i had thatflasherclicking soundcoming from the pass side flasher.
It would stop with pressing the brake peddle. If you just lightly touched the signal arm it started the flasherclicking but not flashing the lights it would also start randomly.
The washer and wipers operate normal but i have no hazards or signals at all now.
Any ideas as to what is up now or my next step?
Thanks Ross
Old Jun 11, 2007 | 02:53 PM
clone432's Avatar
clone432 is an unknown quantity at this point
Default RE: multifunction switch
I would check and make sure all the wire connections were fastened securely. I just changed mine on my '95 and it was pretty hard to get to a couple, especially those under the dash.
Did you replace with a new switch or out of a junkyard. Mine was a non-GM off ebay.
Let us know how it goes.
joe
Jul 5, 2009 06:14 PM
white96LT
Jul 19, 2007 09:03 PM
joe
Jul 13, 2007 04:37 PM
joe
Jun 19, 2007 07:13 PM
mselva
May 16, 2006 04:07 PM
