Turn Signal Noise
Old Apr 23, 2006 | 11:51 AM
mdhokenson's Avatar
mdhokenson is an unknown quantity at this point
Default Turn Signal Noise
The noise that you hear when you use the turn signal comes on when the turn signal is not being used. It does this every now and then and is starting to drive me crazy. Is it some sort of relay that is malfunctioning?
Old Apr 23, 2006 | 03:41 PM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
Default RE: Turn Signal Noise
Possibly, Do the lights flash when that happens? Maybe your turn signal switch is going bad.
Good luck!
Old Apr 23, 2006 | 04:00 PM
mdhokenson's Avatar
No the lights don't flash, just the noise. That's why I can't figure it out.
Old Apr 23, 2006 | 04:07 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Definitely a relay. I've had that in another Chevy I had. Drove me nuts for months. It was a relay in the dash causing it. Should find out what relays are located in that section and see if that fixes it.
Old Apr 23, 2006 | 08:07 PM
Nomad76lj's Avatar
Nomad76lj is an unknown quantity at this point
i know the relay in my 99 is behind the dash. tip the dash forwad by relesing the plasic clip and it has a i think red strap holding its very easy to tell just turn yuor blinker on and go from there.
Old Apr 26, 2006 | 07:23 AM
magtec's Avatar
magtec is an unknown quantity at this point
is it the same rhythmic ticking that the blinkers make? my '97 blazer makes a sound very similar to a relay click, but only when the heater is on. i think it's the defroster vent in the dash expanding and contracting. it's pop riveted on, so i haven't been able to test that theory.
Old May 4, 2006 | 03:49 PM
mandi's Avatar
mandi is an unknown quantity at this point
MD: Did you find out what the problem is with the noise? Iam having the same exact issue right now in a 98. but everyonce in a while it sounds like its shorting something out. But it is comming from behind the passenger side dash. Im affraid of tearing the dash appart b.c i dont know what i have to watch for with the air bag.
thanks
Old May 4, 2006 | 04:25 PM
mdhokenson's Avatar
Unfortunately I did find out what it was. The entire turn signal switch needed to be replaced. They usually run about $200-300, but I found a new GM one on ebay for $105. If you need one let me know and I will give the guy's name.
Old May 5, 2006 | 12:05 AM
mandi's Avatar
Ill def. take his name if its the same issue. I was driving today and realized the noise isnt the same "rythme" as the turn signal click did yours sound just like the turn signal noise?
Old May 5, 2006 | 04:27 PM
mdhokenson's Avatar
Yes, it was the turn signal noise. It would stop and start even when not using the signal. The noise came from behind the glove box in the signal flasher. Tried replacing that first and no luck. I got the turn signal switch yesterday from the guy on Ebay and it was a genuine AC Delco new in the box part. For $105 I am very happy. I am at work now, but will post the guys name when I get home.
