My girlfriend has a 95 jimmy. The front u-joints are making a clicking noise.
My girlfriend has a 95 jimmy. The front u-joints are making a clicking noise. I'm want to replace both sets, but I've never done it. I was wondering how difficult it is and if there is a sticky on here that will walk me through the steps. I consider myself a below average shade tree mechanic.
Are you referring to the joints on the driveshaft that goes from the transfer case to the front axle or are you referring to the front drive axles that are connected to the front tires?
The driveshaft will have u-joints and the drive axles will have CV joints.
I that that might be the case but wasn't sure. CV joints are known to click during turns when they go bad.
Our Blazers have an independent front suspension (IFS) that uses CV-joints to drive the front wheels much like how a a front wheel drive car is set up.
But many 4wd trucks have a solid axle suspension (SAS). Examples of these would include your classic Jeeps.
Unfortunately I have never replaced the front drive shaft u-joints.
I have replaced them on an old Dodge Dart. These often can involve the use of a press.
Perhaps someone else here can help you with specific advice.
First, I would confirm that it's actually the driveshaft u-joints making the noise and not the ale shaft CV joints. Noise from the axle shafts is much more common. The driveshaft will normally only make noise in 4WD, and the axles will be much worse when going around turns. Also, look at the rubber boots on the CV joints, If they're torn, the joints are probably junk.
I believe the front driveshaft has a weird u-joint at the transfer case end that isn't easy to change. But my personal experience with it is limited to removing it and throwing it away a few years ago. If you can't find info on here about fixing it, YouTube probably has something.
It only makes the clicking noise going in a straight line. The noise increases in speed the faster you go. I called AutoZone to get a quote on cost because I'll probably have to save up the money. They said there only two u-joints. One at the transfer case and the other at the rear of the vehicle. Maybe this sound is something I haven't even considered yet.
