Need AC Electrical Diagnostic Help.
Old May 18, 2013 | 09:17 PM
spittybays
Guest
Posts: n/a
Default Need AC Electrical Diagnostic Help.
Hi guys, indent style HVAC control. Obd 1.5 only code is post cat o2 heater.
All heat and fan OK.
Compressor clutch will engage only with direct 12v jump. Both high and low side switches currently jumped closed, relays have been swapped.
Visual wire and fuse inspection.
No metering tests done yet, don't know were to start.
Any help to get me going on an organized path would be a great help.
Thanks Jeff.
Old May 19, 2013 | 07:07 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
fist step is insuring you have freon in the system and how much pressure there is. Only after that checks out can you move on to electrical.
Old May 19, 2013 | 09:24 AM
spittybays
Guest
Posts: n/a
High side and low side both jumped closed with a full charge. Freon is out of the =tion.
Does anyone know the readings I should be getting from the head unit maual switch?
safari2000
Jun 27, 2012 04:09 AM
Vicer_Exciser
Nov 6, 2010 02:30 PM
TomSawyer
Apr 19, 2009 07:29 PM
pmezo
14
Feb 8, 2009 04:45 PM
junkmonkey
Aug 6, 2007 01:48 PM
