need advice
Hey that is the new improved spider I was looking for to put in the used engine I purchased to replace the old engine that has a stuck valve. I see Amazon has the best prices on AC Delco so I think I will just use AC Delco. For $55 and no more labor you can replace the water pump and thermostat from Amazon while you are under the hood.
ok so i ordered all my parts .
What should i use on my lower intake for a sealant in addition to the felpro gaskets.
i was think of useing a light coat of rty silicone on the heads and apply intake gasket to it and allow to firm up before setting my intake back in place.
is this ok to do
is this ok to do
I have the same install questions since I have not yet done the job.
Where did you get the parts at that price. I see Amazon has it for $185 but with 2-5 WEEK ship date where the other sellers have it in stock but it is more like $240 on Amazon?
They only had 1 in stock at that price i think you might be S.O.L sorry
Order Total: $367.07
Delivery estimate: Jan. 5, 2012 - Jan. 10, 2012
1 "Fel-Pro MS98002T Prmdry Intk Manfl Gsk Set"
Misc.; $65.32
In Stock
Sold by: Amazon.com LLC
2 "Fram PH3980 Extra Guard Passenger Car Spin-On Oil Filter, Pack of 1"
Misc.; $3.57
In Stock
1 "Delphi FJ10565 Fuel Injector"
Automotive; $182.42
1 "ACDelco PF458G Oil Filter" "[for wifes equinox]
Automotive; $10.02
In Stock
1 "Delphi FH10098 Fuel Injector Retaining Bracket"
Automotive; $21.38
In Stock
1 "ACDelco D465 Distributor/Ignition Rotor"
Automotive; $8.15
In Stock
1 "ACDelco CV769C PCV Valve"
Automotive; $7.23
In Stock
6 "ACDelco 41-993 Professional Platinum Spark Plug , Pack of 1"
Automotive; $5.48
In Stock
1 "FRAM G8219 In-Line Fuel Filter"
Misc.; $9.40
In Stock
1 "ACDelco D328A Distributor Cap"
Automotive; $23.13
In Stock
ok job finished and it runs better than ever . wow what a difference with the new spider and a tune up.
I had issues before with hard starting because of leak down . well not anymore jump in turn the key and it fires right up. i would have bet money my fuel pump was bad.But i guess not.Hold right at 58lbs now awesome.
Sounds good.
I get that upgraded port injector spider for the 2002 since we have it in the 1998.
What is the point after 200k to wait for it to start wash down the cylinders and wasting gas which may pay for the $180 up grade.
boomtruck97
Jan 8, 2010 01:34 AM
rcravincase
Sep 13, 2009 07:58 PM
