Suspension Tech Have a question about modifying your suspension? Ask it here.
Lowered problem, need advice!
Old Oct 10, 2004 | 08:46 PM
TerribleOne's Avatar
TerribleOne is an unknown quantity at this point
Default Lowered problem, need advice!
my blazer is lowered 4 inches in the back and when i go over bumps in the road the underbody above the rearend, it hits hard and sounds like crap, tried bump stops but makes the ride really ruff. i need simple solution until it gets bagged.
Old Oct 10, 2004 | 09:27 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Lowered problem, need advice!
if it hits the frame rails, notch 'em. thats really the only thing you can do.
Old Apr 27, 2005 | 03:50 PM
TinnMan's Avatar
TinnMan is an unknown quantity at this point
i have a bagged blazer all you can do is notch the back. you can buy a bolt in small notch that notches the frame like 2inchs from suicidedoors.com its only like 40.00 i think wich really aint that bad for ride quality. and the good thing is that make a notch for the crooked frame blazers and the straight frame. hope that helps TinnMan
RedXtreme04
Suspension Tech
Oct 29, 2007 06:34 AM
splat
Mar 26, 2007 09:09 AM
CashSax
Suspension Tech
Jan 31, 2007 10:00 PM
troy
Jun 20, 2006 09:41 PM
lbcstyles
Suspension Tech
Jun 16, 2006 10:23 PM
