need help 2000 gmc jimmy
Old May 1, 2017 | 11:53 PM
odomatt's Avatar
odomatt is on a distinguished road
Default need help 2000 gmc jimmy
hello.i hope someone can help me.i have a 2000 gmc jimmy.i was in the drive through at mc donalds.my truck just shut off with no warning.no check engine light came on.it just cranks and does not start.im getting spark from the coil.i have fuel pressure from the shrader valve.i can hear the fuel pump turn on.i hope someone can help me out
Old May 2, 2017 | 06:08 AM
newguy's Avatar
Yuo need spark at the plugs and what psi are you getting at the shrader valve?
Old May 2, 2017 | 12:57 PM
odomatt's Avatar
i wasn't able to check actual fuel pressure.i put new spark plugs in back in November.when this all happened it was running great and no check engine light or anthing
Old May 2, 2017 | 04:49 PM
stonum's Avatar
stonum is on a distinguished road
What happens if you pour a little gas into the throttle body? Or spray some starting fluid in there?......Careful..Keep yourself away from throttle body opening in case of a backfire.
Old May 3, 2017 | 06:46 AM
chevyriders's Avatar
I think what newguy meant was that you could be losing spark somewhere between the coil and plugs.
If you're not getting spark at the plugs ,Coil wires tend to go bad, and since youre not firing in any cylinders, that would be a good place to start. Measure resistance(ohms) from one end of the coil wire to the other. Could also remove the distributor cap and check it, and the rotor
Old May 3, 2017 | 08:09 AM
Tajohns34's Avatar
This might help, read the whole thing. https://blazerforum.com/forum/2nd-ge...n-88305/page5/
Nativewayz
40
Apr 21, 2020 01:38 PM
pauldiguer1998
Suspension Tech
May 5, 2016 01:39 PM
Travis West
Oct 31, 2014 10:19 PM
extreme
Dec 1, 2010 06:08 PM
londonmazda
Oct 19, 2010 02:15 AM
