need help asap
Old Feb 5, 2009 | 07:01 PM
layzdoorz's Avatar
layzdoorz is an unknown quantity at this point
Default need help asap
ok the battery in my blazer was bad so i replaced it and as soon as i put it in , the dash lights would not come on but the fuel guage on the dash worked , all the other lights come on , it turns over fine , fuel pumpcomes on but it wont start . but if i leave the key turned to the accsessary the dash light would come on after 5 seconds or so then it would start and there was a slight clicking noise before the dash lights came on. now the dash lights wont come on and it wont start . can someone please help me troubleshoot this?
Old Feb 5, 2009 | 07:20 PM
NVANZEE's Avatar
Default RE: need help asap
first off this isnt the area to post problems. it needs to be in the tech section. (a mod will probably move it for you). Second we need to know the vehicle information.
Old Feb 5, 2009 | 07:23 PM
layzdoorz's Avatar
i tried but it wont let me do a new post in the general tech area for some reason?
Old Feb 5, 2009 | 09:38 PM
No one can post in the Gen Tech section. You must choose the appropriate section. But since you already have this thread, there is no need to double post.
I will move this to the appropriate section once you give us a shred of information about your vehicle... Year, engine, drivetrain, and anything else you feel applies would be a good start.
Old Feb 5, 2009 | 10:01 PM
Tdotblazer's Avatar
Tdotblazer is an unknown quantity at this point
my mechanic told me blazers have been known to get loose grounds in the cab
does this make sense?
Old Feb 6, 2009 | 05:33 PM
layzdoorz's Avatar
i dont know where to put the info for my blazer so here it is 97 blazer 4.3 4wd . sorry to everybody that i double posted , im new on here so my bad!
Old Feb 6, 2009 | 06:12 PM
rriddle3's Avatar
I moved this to the correct section for you. You can go into 'My Profile' and create a signature with your vehicle info (see mine below for example).
Old Feb 6, 2009 | 08:06 PM
This sounds like an ignition switch issue.
layzdoorz's Avatar
ok thanks alot rriddle3 . any help with the problem would be greatly appreciated , anybody please!!!!!!
Old Feb 6, 2009 | 08:10 PM
rriddle3's Avatar
Well, did you read Kyles' reply?
