NEED HELP ASAP!!! water leak inside!
Old Nov 12, 2012 | 07:09 PM
hitechracing's Avatar
hitechracing is on a distinguished road
Default NEED HELP ASAP!!! water leak inside!
Hey guys i really could use some help. I have done a lot of research and have not been able to answer my exact problem.
i have a 2000 chevy blazer lt 4 door 4x4.
my drivers side carpet is soaking wet. it is water not antifreeze. i have found the water leak in front of the parking brake, there is a hole in the oem sealer. i took the little part of the cowl off, making the hood hinge visible. poured water ontop of the hinge and bolt area, and then water pours into the cab through the hole. Now my problem is i cannot seam to pin point where the water is entering from the top.
any ideas would be greatly appreciated!!!
Old Nov 12, 2012 | 09:07 PM
neo71665's Avatar
Spray on bedliner. Clean and scuff as best as you can and lay it on thick.
Hunter_Zack_1994
May 7, 2012 03:54 AM
rodrigomorales00
Jun 28, 2011 06:51 AM
Jonas
Jul 14, 2010 09:21 AM
xXJump4JesusXx
Jun 29, 2010 08:10 PM
mikeinwi
May 30, 2008 10:48 PM
