need help blazer over heated and died!
Old Jul 22, 2010 | 10:22 AM
rockislife04's Avatar
rockislife04 is on a distinguished road
Default need help blazer over heated and died!
i have a 98 blazer. i was away for 2 weeks and my family thought it was a good idea to use my car. they drove it and it over heated like 2-4 times and now it wont start. i got a buddy of mine to bring over his rad odb reader(almost **** myself when i saw it) and it had codes. The codes are p01117, p0300, and p1114. Also he looked at each cylinder and it says that 1,3,and 5 were all misfiring. 5 like 1000+times 3 like 600+ times and 1 like 100+ times. if anyone could help me out here i would really appreciate it. I think it might be like a timing problem and then maybe the head warped after it over heated. just help please.
Old Jul 22, 2010 | 10:51 AM
P0117 and P1114 both point to a faulty ECT (engine coolant temperature) sensor or a problem with its circuit. This could contribute to the misfiring. Does the coolant temp gauge on the dash actually work?
I would want to test compression on that side of the engine to assess the damage. Will the engine turn over?
Old Jul 23, 2010 | 11:47 AM
yess it will turn over and yes the temp gauge works. it jsut wont fire.
Old Jul 23, 2010 | 12:26 PM
Old Jul 25, 2010 | 09:44 PM
ok well i threw a fresh battery in there tonight and got it started and got it home but it ran like total crap. it had the same running prblems as when i first got it with the fuel filter so i will check that and replace the thermostat for good measure and go from there. i will keep you updated. ty
Old Jul 26, 2010 | 09:08 PM
chevy ll man's Avatar
chevy ll man is on a distinguished road
try changing spark plugs you can damage spark plugs when the engine over heats
Old Jul 26, 2010 | 10:02 PM
ok well today we thought it would be a good idea to work on the coolant system. we changed out the thermostat and everything went good. Then we flushed the radiator and refilled.Thats when it went bad. We ran it for a min or two and all of the sudden a huge cloud of white smoke started pouring out of the tail pipe. Now it wont start and i think we may have blown a head gasket. If this sounds correct let me know.
Old Jul 27, 2010 | 06:17 AM
Possible, but you could have blown the lower intake manifold gasket into one of the intake ports. A compression check will let you know.
Old Jul 27, 2010 | 11:58 AM
that would be a blessing alot easier to fix than a head gasket!!! we will check and let ya know.
Old Jul 27, 2010 | 01:41 PM
tonto5968's Avatar
tonto5968 is on a distinguished road
not that far from putting head gaskets on it. might as well do it while its apart. then u will know what u got
1997GreenBlazer
May 20, 2021 09:00 AM
Jason Nowell
May 30, 2015 06:39 PM
chris015
Jul 8, 2012 01:19 AM
big david
Jun 17, 2012 09:00 AM
wetbar
Sep 24, 2011 04:51 AM
