Need help changing thermostat please.
Ok fellas. I know I might seem dumb for asking this, but I cant get to the thermostat housing bolts to take it off and change the thermostat. The blazer is a 95 with a 4.3, and I cant get the wretchet in there. There seems to be a some kind of a support member in the way thats located right behind the AC compressor? extending to the bottom of the alternator. I cant get no tools down in there to unbolt the damn bolts, and its just straight up pissin me off. Whats a way of doing it, anyone!???
any one???
first thing is to take the air intake tube off, its right in your way, next is to remove the belt and then the upper radiator hose on the thermostat side and with a 3/8 universal joint, a short socket and 6 inch extension you should be able to get at the bolts. hope this helps.
Wow... You waited an hour... Did you ever consider removing that bar that is in your way??? Probably not since you were so impatiently waiting... In the future, do not bump a post until you have waited at least 24 hours. After all, rules are rules. first thing is to take the air intake tube off, its right in your way, next is to remove the belt and then the upper radiator hose on the thermostat side and with a 3/8 universal joint, a short socket and 6 inch extension you should be able to get at the bolts. hope this helps. |
I wouldn't worry about where the tensioner is. It's going to end up being whatever tension it is. Sometimes you just have to bite the bullet and take stuff apart enough to do the job. You'll find out it's quicker that way most of the time. Besides, just think of all the valuable experience you'll be getting. Do you have a service manual of some kind? That would be the first "tool" I would get.
heres what you need..... http://img202.imageshack.us/img202/5073/200901312.jpg the bolt that is in the box is the tensioner release bolt, its a 15mm and i believe that you turn it counter clockwise to take the tansion off of the belt. |
I wouldn't worry about where the tensioner is. It's going to end up being whatever tension it is. Sometimes you just have to bite the bullet and take stuff apart enough to do the job. You'll find out it's quicker that way most of the time. Besides, just think of all the valuable experience you'll be getting. Do you have a service manual of some kind? That would be the first "tool" I would get. this link doesnt help him, he has a 95 blazer which has the CPI motor in it and the thermostat location is diffrent. heres what you need..... http://img202.imageshack.us/img202/5073/200901312.jpg the bolt that is in the box is the tensioner release bolt, its a 15mm and i believe that you turn it counter clockwise to take the tansion off of the belt. |
I dont know where the other end of that bar goes, you may be able to take the tensionioer off and gain access to it but im not 100% sure of that. i would try the universial joint and a short socket first, its the easiest way IMO
| All times are GMT -5. The time now is 11:25 PM. |
