need help with torsion bars
Old Apr 14, 2009 | 02:53 PM
determan's Avatar
determan is on a distinguished road
Default need help with torsion bars
I have a 2000 2 door ls im havin trouble getting my torsion bars set right i replaced the wheels to havin 2 inch backspacing all other specs on the wheels are the same as factory but my question is i need to know where to set my torsion bars to if i crank them to clear the wheel my truck slams into bumps rather than rollin over them but when you drop them the wheels hit the inner fender i see all sorts of blazers that are stock and their still sitting higher than mine what is factory height and what else can cause a slamming my mechanic says that its not the shocks cause they only keep the truck level
Old Apr 14, 2009 | 04:53 PM
Colby 04's Avatar
Colby 04 is on a distinguished road
That is one very long sentence lol
Your shocks are designed to absorb bumps. Go push down on the vehicle and rock it, does it keep rocking or does it stop pretty quick? That's a quick and dirty test for your shocks.
Old Apr 14, 2009 | 09:00 PM
determan's Avatar
it rocks a little my mechanic said that theyre ok but not perfect i have fishtailed because it slams bumps and doesnt roll over them it also shimmies down the freeway ive had alot of gm ddealers look at it with no luck
Old Apr 16, 2009 | 02:24 PM
2" back spacing... That is just ridiculous. You need to stay in the 4-6 range with your wheels or you will be looking at MAJOR suspension modifications just to be able to turn.
What size tires are you attempting to run with the 2" BS rims?
spider21
Sep 13, 2012 12:57 PM
jdub9000
Jan 10, 2011 03:57 PM
98blazr
May 5, 2009 09:30 AM
beeneeb
Dec 7, 2004 05:10 AM
