Need Help - Wont Start in The Rain
Old Feb 16, 2022 | 07:31 PM
tony991's Avatar
tony991 is on a distinguished road
Default Need Help - Wont Start in The Rain
My buddy is having trouble with his 2001 ZR2 Blazer.
What do you guys think?
Here's a video of him explaining his situation.
We'd appreciate any help you guys provide!!
Old Feb 16, 2022 | 11:54 PM
Have you noticed any electrical get wet? Does it have any power when raining? Does it crank and not start? I think there's some more info needed to get a better idea what we are working with...
Old Feb 17, 2022 | 08:27 AM
tony991's Avatar
I'm not sure if he noticed any electrical getting wet. I'll ask him. It does have power when it's wet - Everything seems to work fine. It cranks over but doesn't even try to fire.
Old Feb 17, 2022 | 10:05 AM
GeorgeLG's Avatar
Its fuel, spark, timing or air.
First do the fuel pressure test in the sticky at the top of the second gen forum. Key on pressure and leakdown at the schrader valve. Retest while cranking.
If that's OK then test for spark on at least two plug wires at the plug ends while cranking
If that's OK then we move on to fuel injector pulses and timing
Do you have a scanner with live data capability?
George
Old Feb 17, 2022 | 06:50 PM
Have you tried to force the symptoms by spaying water from a hose on different parts of it.
If the individual components are good, then I'd look at shorts in the wiring harness. If the insulation is damaged, if wet, you could get a short.
Old Feb 18, 2022 | 07:57 AM
LannyL81's Avatar
What GeorgeLC says....
But also check the wiring harness going to the ECM/ECU for damage.
Bow_Tied
Jan 25, 2018 06:43 PM
Kangblazer
Jun 15, 2017 03:40 PM
swells87
Nov 12, 2014 05:10 PM
Blazer2000LT
Apr 27, 2013 01:52 PM
willtoskie
Jan 22, 2010 12:44 PM
