Need PSI info
Old Dec 15, 2013 | 01:07 PM
multitrack24's Avatar
multitrack24 is on a distinguished road
Default Need PSI info
Wondering if anyone can help me out with the PSI listed on the drivers door for 2004 ZR2. My sticker is faded.
Old Dec 15, 2013 | 07:57 PM
If you go by the door jamb sticker, you'll get a softer ride, less fuel mileage, and the tires will wear out quicker. For the best fuel mileage and tire longevity, inflate them to 10% less than the maximum pressure listed on the sidewall of the tire. If it says 44psi, inflate it to 40psi, etc.
Old Dec 15, 2013 | 08:42 PM
richphotos's Avatar
What cap said... that is what I do, my tires list I think 38-40psi, I fill to about 35psi
Old Dec 16, 2013 | 06:17 PM
Thanks guys!
Old Dec 16, 2013 | 06:27 PM
rriddle3's Avatar
I used to run the fronts at 35 and the rears at 33.
Old Dec 16, 2013 | 09:10 PM
LeWhite's Avatar
As Capn said. But you also have to factor in the pressure before you inflate. Whatever your personal inflation interval if you have a tire that is 10%below the others THAT tire should be given a 10% boost in pressure. That way all tires share closer pressures for the longest time. e.g Mine get 39,39,40,38. When I next check them I get 36,36,34,35
Fivspeed
41
Jul 22, 2013 07:40 AM
94NDTA
Mar 10, 2008 04:20 PM
joey
Aug 8, 2007 12:37 PM
DavidBoone
Jun 21, 2006 07:46 PM
93LT
Jan 16, 2006 09:36 PM
