Need some guidance on fuel filter change
Old Nov 27, 2010 | 05:51 PM
Vicer_Exciser's Avatar
Vicer_Exciser is on a distinguished road
i cant see or feel where to put the socket and wrench.. and also theres not really any room to do this.
i am just limited on time to fix my truck, im either working or when i do get out of work its too dark and now too cold.
Old Nov 27, 2010 | 06:47 PM
There is room. I have done it many times on numerous different s-series vehicles front 1st gens to the end of production on the 2nd gens. The pictures in the How-to article show you where the bolt is and tell you what size socket to use.
Usually getting the threaded connection apart is the hassle. From there, it's less than 5 minutes worth of work.
As a tip, coat the threads and the end of the hard metal line where the swivel nut sits with anti-seize to make it easier to take apart the next time.
Old Nov 28, 2010 | 09:54 PM
stanitis's Avatar
stanitis is on a distinguished road
Just for Your information, You don't have to do what I did but, My bracket (fuel filter retainer) would not come off so, I cut the plastic bracket from left to right and between the tension from the fuel lines & being able to set the new fuel filter back inside of the "plastic retaining bracket", it holds just fine. It doesn't rattle around nor seem un stable & I am pretty picky about things being correct, I sleep comfortably over this one! Good luck.
ferret13sj
Mar 8, 2015 06:45 PM
hargrovewill
Apr 21, 2014 06:26 PM
jatkins3983
Headers, Intake, & Exhaust
Oct 24, 2013 08:23 AM
OffRoadNLovinIt
Jul 8, 2013 12:48 AM
metalmilitiacdr
May 2, 2011 07:29 PM
