need some help
Old Jan 29, 2014 | 10:15 PM
jlboots's Avatar
jlboots is an unknown quantity at this point
Default need some help
front diff not locking before and after installing a posi lok the t case is working was should only thing I can think of is that its something inside the front diff that is broke
Old Jan 30, 2014 | 01:07 AM
Diaita's Avatar
Front vacuum actuator working?
Old Jan 30, 2014 | 11:37 AM
jlboots's Avatar
Replaced with a posi lok kit
Old Jan 30, 2014 | 12:08 PM
rexmburns's Avatar
Super Moderator
are you sure the cable is pulling properly?
Old Jan 30, 2014 | 12:42 PM
newguy's Avatar
Try rolling a bit while pulling the cable
Old Jan 30, 2014 | 01:26 PM
spittybays
Guest
Posts: n/a
+1^^^ also make sure that crappy little spring clip is engaged at the bottom of the cable.
Old Jan 30, 2014 | 01:57 PM
Diaita's Avatar
Yea, what I meant... No more late night posting for me....
Old Jan 30, 2014 | 04:29 PM
cleaveley's Avatar
cleaveley is on a distinguished road
the seals in the 4WD actuator are probably gone, very common problem expecially if you had a leaky battery becuase its located under the battery. pop the battery out and see if you have vaccum pressure in the actuator and make sure the rubber is ripped. & then and see if the cable is seized or not.. if everything looks fine, but there is no vaccum pressure its the switch on the side of the transfer case, cheap fix but a pain in the A$$. Other than that I could only think that maybe the cable isn't adjusted properly on the side of front diff.. when you took the diff out and removed the cable maybe now it needs re-adjusted.. also there is a shift fork in the front of that diff and if you put it in backwards it wont engage, & or that could be broken if you engaged the four wheel at a high speed.
hope this helps !
Old Jan 30, 2014 | 05:23 PM
rexmburns's Avatar
Super Moderator
He removed the vacuum actuator.
Old Feb 5, 2014 | 08:41 PM
jlboots's Avatar
ok so I got around to checking it the plastic house the holds the cable is stripped on the inside so now I have to fined it at a junk yard which is going to suck
Wyatt Abshire
Jul 12, 2012 08:27 AM
davidluzader
Mar 1, 2010 10:25 AM
rcravincase
Sep 13, 2009 07:58 PM
ZLover4Life
46
Dec 22, 2008 01:01 AM
scottyk
Mar 19, 2007 11:32 PM
