Need some help whit this, Program a 2000 Chevy S-10 Key FOB problems
Old Jun 21, 2011 | 05:24 PM
gulljenta's Avatar
gulljenta is on a distinguished road
Default Need some help whit this, Program a 2000 Chevy S-10 Key FOB problems
I have read on the web how I do it, but it will not enter learn mode.
I hope that this is the right thing too do?
This is what I have done. But when I came too where the car should answer with lock and unlock nothing happens.
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
Old Jun 21, 2011 | 08:43 PM
This brings back memories:
Originally Posted by swartlkk
Here is my response to another thread entitled OEM Remote which may be of some help (it also links to a few other threads on the subject). The keyless entry fob thread has quite a bit of information in it as well. If you cannot get it into program mode and you do have an RKE module, I would check your fuses to make sure that something isn't blown. If everything is good, then you may have to get the dealer to initiate the programming of the fob (some vehicles are finicky...).
Old Jun 28, 2011 | 08:26 PM
gulljenta's Avatar
ok, but I live in Sweden. Is it the same here or is it something else you can do?
changeme20
Oct 24, 2020 02:12 AM
justblazin1
Dec 19, 2018 01:41 AM
NICKC
Jun 3, 2013 05:18 PM
Droidster
Apr 26, 2013 03:04 PM
