Need some major help!!
Old Mar 11, 2013 | 08:20 AM
jhug1994's Avatar
jhug1994 is an unknown quantity at this point
Default Need some major help!!
i have a 1998 blazer 3 button 4x4 have replaced encoder motor, tccm, bypassed vacumn diaphragm, replaced vacumn switch and front differiential switch still does not work
Old Mar 11, 2013 | 12:04 PM
Spree's Avatar
Spree is on a distinguished road
Do your lights, light up on the buttons? My buttons went bad and was stuck in 2 wheel drive. Removed buttons and re-soldered back of circuit board and been working ever since.
Old Mar 12, 2013 | 05:52 AM
jhug1994's Avatar
Yes they just flash and go right back into 2hi then after awhile of trying just click
Old Mar 12, 2013 | 12:57 PM
Spree's Avatar
Try what I said above or buy new switch from rockauto.com.
Old Mar 12, 2013 | 02:07 PM
LannyL81's Avatar
When the 4HI button is pressed do you hear or feel anything? Put the transmision in park or neutral to do this.
If you hear or feel a clunk....technical term there....then the encoder motor is working.
What do you mean that the vacuum diaphram has been bypassed? Have you checked...better yet replaced the vacuum lines between the engine intake, to the reservior to the vacuum switch, to the diaphram? Especially check in the left corner of the engine compartment...that is where the vacuum lines rot out for some reason.
Old Mar 13, 2013 | 08:13 AM
jhug1994's Avatar
I put a pull cable on the front axle cable to lock it in and when i press it i dont hear anything but i took the encoder motor off and tryed engaging it and the motor wheel did not move but the buttons lit up 2hi and 2lo
CHEVYBOY89
Sep 28, 2013 01:21 AM
blazerbagpipes
Oct 16, 2012 09:37 AM
blasterdukes
Sep 5, 2011 04:40 PM
santmire
May 28, 2011 01:39 PM
TenaciousFBC
Nov 6, 2009 04:07 PM
