need some power window help please
Old Jan 31, 2009 | 06:50 PM
IROCZ's Avatar
IROCZ is an unknown quantity at this point
Default need some power window help please
ive got 97 blazer LS 4dr. all the windows work from drivers side control but wont work from any of the other controls? it was working the other day and the lock isnt on??
Old Jan 31, 2009 | 08:45 PM
IROCZ's Avatar
Default RE: need some power window help please
bump
Old Jan 31, 2009 | 09:47 PM
flyinquack's Avatar
flyinquack is an unknown quantity at this point
i had the same problem when i first got my blazer. all i did was clean the connections in the lock switch. took 5 minutes. just be careful not to break any of the plastic clips... theyre fragile in the cold.
Old Jan 31, 2009 | 11:37 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Sounds like you have a bad widow lock-out switch...
Old Feb 1, 2009 | 08:33 AM
IROCZ's Avatar
thanks guys im going to check it out today ill let u know if i fix it
Old Feb 4, 2009 | 09:53 AM
IROCZ's Avatar
cool i fixed it all i did was removed the cover and pushed the connector back in better. simple loose connection thanks guys
Jimmy Williams
Feb 16, 2013 11:36 AM
Wyatt Abshire
Jul 12, 2012 08:27 AM
davidluzader
Mar 1, 2010 10:25 AM
chrisjanicki01
Nov 14, 2009 05:45 PM
scottyk
Mar 19, 2007 11:32 PM
