need spark plug wiring diagram NOW!! Backfiring real bad!!
Old Nov 11, 2010 | 12:45 PM
Mange98's Avatar
Mange98 is on a distinguished road
Exclamation need spark plug wiring diagram NOW!! Backfiring real bad!!
I really need to see what wires go with what cylinder, i just replaced the wires and fired it up and it's backfiring real bad. PLEASE HELP!!!
Old Nov 11, 2010 | 02:34 PM
rriddle3's Avatar
Here's the firing order diagram, if that's what you're looking for.
Attached Thumbnails need spark plug wiring diagram NOW!! Backfiring real bad!!-0900c1528008ee21.jpg
Old Nov 12, 2010 | 09:15 PM
g_mike's Avatar
g_mike is on a distinguished road
the cap is the same order for passenger side but driver side 1 and 3 are reversed for order of plugging it in.
it is marked, i had the same issue i thought i matched it up the same but 2 wires got mixed up and mine was backfiring like crazy.
Old Feb 23, 2011 | 02:00 PM
BEAT MY JIMMY's Avatar
BEAT MY JIMMY is an unknown quantity at this point
This doesn't make sense. If that is the correct firing order diagram, wouldn't that make the firing order 1-3-2-4-6-5. I was under the impression the firing order was 1-6-5-4-3-2 with the rotor traveling clockwise. I'm very confused now.
Old Feb 23, 2011 | 02:07 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
the diagram does show the firing order as 1-6-5-4-3-2. how do you see 1-3-2-4-6-5???
Old Feb 23, 2011 | 04:49 PM
Well if the rotor spins clockwise, and you follow the wires on the cap starting with #1, you would have a firing order of 1-3-2-4-6-5. However, what I just found out is this... if you look inside the cap. you can see that the connections inside DO NOT corespond with the wire towers on the outside of the cap. there are conductors embedded in the cap to keep the firing order correct.
Old Feb 23, 2011 | 07:05 PM
Old Feb 23, 2011 | 07:06 PM
rriddle3's Avatar
Good lord, people, look at the picture I posted. Starting with the #1 on the distributor cap and going clockwise gives 1-6-5-4-3-2 and the wires are showing as going to the same correct cylinders in the same number order. How can this possibly be confusing? That's why I chose a photo that showed the cap in the traditional round form to make it simple.
Old Feb 23, 2011 | 07:15 PM
It's confusing because post #2 shows a 1995 and older cap. Post #7 is 1996 and newer.
Old Feb 24, 2011 | 06:19 AM
This pic shows it perfectly. If you look closely, you can see each of the wire towers are numbered. You can also see the raised tubes on the cap. If you follow the tube from the #1 wire tower (middle tower on the side with 3), the pin on the inside of the cap that makes contact with the rotor is actually located directly below the round depression between #2 & #4 wire towers. I have been working on vehicles for about 30 years now, and have never seen a cap that does not follow the firing order. That is why this was so confusing to me. I would have expected this kind of design from a foreign auto manufacturer... not GM.
http://www.facebook.com/l.php?u=http...in.JPG&h=70f98
