needing cam compression info
Greetings,
there's no such thing as a stupid question rite? Ok, I need some numbers please if possible. Does anyone know the stock cam duration @.050? Also what is lobe separation? And final question; what is/ how the heck does one figure out the compression ratio static/dynamic?? Any & all help is greatly appreciated. thanks for your time & help. Btw- this is regarding a '99 Chevy blazer 4.3lvortec. |
Stock roller camshaft for Blazer Brand: Sealed Power Manufacturer's Part Number: CS-1572 Cam Style: Hydraulic roller tappet Duration at 050 inch Lift: 191 int./195 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.414 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.428 in. Lobe Centerline (Exhaust) 116 Deg. Lobe Centerline (Intake) 106 Deg. Lobe Separation 111 Deg. Overlap 32 Deg |
