needing cam compression info
Old Sep 4, 2018 | 03:11 PM
StarScreamin's Avatar
StarScreamin is on a distinguished road
Default needing cam compression info
Greetings,
there's no such thing as a stupid question rite? Ok, I need some numbers please if possible. Does anyone know the stock cam duration @.050? Also what is lobe separation?
And final question; what is/ how the heck does one figure out the compression ratio static/dynamic??
Any & all help is greatly appreciated. thanks for your time & help. Btw- this is regarding a '99 Chevy blazer 4.3lvortec.
Old Sep 7, 2018 | 11:10 AM
LesMyer's Avatar
Stock roller camshaft for Blazer
Brand: Sealed Power
Manufacturer's Part Number: CS-1572
Cam Style: Hydraulic roller tappet
Duration at 050 inch Lift: 191 int./195 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.414 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.428 in.
Lobe Centerline (Exhaust) 116 Deg.
Lobe Centerline (Intake) 106 Deg.
Lobe Separation 111 Deg.
Overlap 32 Deg
Old Sep 7, 2018 | 11:20 AM
LesMyer's Avatar
man0steel
Jun 16, 2019 09:48 AM
tkos15
Engine & Internal
20
May 12, 2018 08:08 PM
benthm7
Jun 16, 2011 09:07 AM
97ssblazer
Performance & Brainstorming
Feb 7, 2009 09:36 PM
95blazer4wd
Sep 30, 2008 04:09 PM
