new engine
Old Oct 28, 2005 | 01:13 PM
nslide10's Avatar
nslide10 is an unknown quantity at this point
Default new engine
Ok now i just put a new engine it was bought as a long block so i had to transfer all tins and stuff like that from the old motor to the new one. we got it all put together right and put back in the truck its a 96 blazer s-10 4.3 v6 with the w type motor. now we tried to start it and you can hear it sound like it wants to start we get a few little explosions in the motor but it wont start and run. is there anything i need to do to the computer like reset it or clear any codes an see if it gives me new ones or is there something i should try to make this thing work??? any suggestions would be greatly appreciated thank you!!!!!
Old Oct 28, 2005 | 01:33 PM
tdannar's Avatar
tdannar is an unknown quantity at this point
Default RE: new engine
Is the distributer in properly? Engine TDC, Rotor pointing at #1 cylinder plug wire, etc? If so, you could be 180 degrees off (could have been TDC of exhaust stroke instead of compression).
Just my guess.
TD
Old Oct 28, 2005 | 04:27 PM
nslide10's Avatar
when i got the engine the timing sprokets were lined up and i have a haynes book that says to line the rotor up between the #6 and the #1 on the distributor cap so than i called the dealer ship an asked a mechanic and he said to point it at the #6 on the distributor and there should be a white dot on top tellin u were to point it. so on the distributor you have to follow the terminals comin off the numbers on the cap on the underside to see where the actual contact is an the white dot was right between the 6 an the 1 terminal so we lined it up with that and we assumed that was right because on the top side the number 5 is inbetween the 1 and the 6. but also im not sure how its supposed to sound when it fires right i dont know if its supposed to be like rhythmatic like pop pop pop or pop skip pop skip it kinda sounded like it wanted to backfire. if i could draw a diagram i would because the description in the book was hard to understand i didnt think it meant under the cap i wasnt sure. i still aint sure it could be off i jus wanna get it started and make sure it runs right pls help
Old Oct 29, 2005 | 12:32 AM
93LT's Avatar
93LT is an unknown quantity at this point
It sounds like it is either 180 degrees off or it is simply too far out of timing.
Old Oct 29, 2005 | 02:49 AM
nslide10's Avatar
well son-of-a-bitch u were right to the tooth 180 degrees off started first turn of key soon as i turned distributor. thank you you made my $2500 investmant worth it not to mention the 2 weeks of tearin down old one and puttin new one together. now i know where to go when i have troubles with my blazer. and again thank you
Old Oct 29, 2005 | 03:18 PM
Talusgirl's Avatar
Talusgirl is an unknown quantity at this point
Damn, $2500. That is why I decided not to replace the engine in my '91. I bought it for $300 and it looks like crap. Still runs but needs a new engine. These guys warned me how much it would be. I ended up buying a newer Blazer. Congrats on doing it yourself!! That is a butt-load of work!
Old Oct 30, 2005 | 01:52 AM
nslide10's Avatar
well mine was free from my bro an its like brand new nice an clean never been smoked in all leather an power an he just had the trans replaced new a month before he burned oil pump up an spun a bearing an body been redone to look pretty again so it was worth it in the long run i got pretty much a newish vehicle with near zero miles an its gonna last bout 10-15 more years
Old Oct 30, 2005 | 12:24 PM
Talusgirl's Avatar
I agree-totally worth it then. Mine wasn't . The engine would've outlasted the body, plus I woul have had to pay somebody to do it.
bigkeith11
Sep 19, 2012 01:12 AM
N.alaska_blazer
Feb 23, 2009 01:31 PM
zombiewoof
Feb 1, 2009 12:06 PM
loppy crimp
Sep 11, 2008 08:31 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
