New guy - Brake light issue
Hi all, this is a great forum. I have a similar problem with my 2002 LS. Checked with Chevy, it was not covered under the recall. When I wiggle the hazard switch I can get the lower brake lights to work. As a first step, I was planning to change out the hazard switch per the Tech Article, ie, pull from the top. Can someone tell me, for a 2002, is it certain that the switch part number is 15174447 or do I first need to dissassemble the column and check the bar code, negating the advantage of pulling out the switch from the top? I guess from reading various posts this could also be due to the multifunction switch, correct? Thanks for any help on this.
My buddy picked up a 98 Blazer today. When we checked it out, we forgot to check the lights. After we left with the truck, I noticed only his 3rd brake light was working. We tried bulbs and they still didn't work. We checked the fuses, they were good. We checked for power at the light sockets, no power. We replaced the brake light switch, didn't fix it. We're not really sure where to go from here. The turn signals, and parking lights all work as they should. Any helpful info would be great!! Thanks.
Good luck trying to find a used one.
Chevy charged me $420 for a new one and I put it in and guess what?...
Still no brake lights. I am at my wits friggin end here so ANY ideas would be more than helpful.
TIA
UPDATE:
OK...it could happen to anyone. I went through and changed EVERYTHING that I thought it could be and still no brake lights. I feel so stupid. To sum it up, I had a broken wire off of the plug-in to the brake switch (pedal). It looked as though it was cut i.e. clean slice. My summation is that it got pinched somehow and cut it right off.
So I'd suggest before any of you start forking out this kind of money you might check your plug-ins first.
Thanks to everyone
Helping someone with a 01 blazer same issue. 3rd brake light works, rear sides do not, but all other functions work. Hazards, turns, running. Have reaplaced the multifunction switch and brake switch. Looked in relay section for CHMSL, oddly even though the cover's diagram has a CHMSL pictured in the area it would go there is no plugin for it, and all other relay slots match with others, like fogs and horn. I have been tracking the wires, but once they return from the brake switch to the main harness I am not sure where they go. If someone has any ideas or a detailed wiring diagram for this it would be appreciated.
Diagrams:
zjones_85
07-05-2013 05:13 PM
SCBlazer96
04-16-2010 08:39 PM
xderkax
01-14-2010 11:38 PM
