New Problem, honestly
Old Aug 17, 2009 | 07:44 PM
pigmak's Avatar
pigmak is an unknown quantity at this point
Default New Problem, honestly
One of my back rotors is not getting hot. Both calipers are new and there is fluid coming in the line. 3 of my rotors get hot, this one just does not.
Old Aug 17, 2009 | 08:23 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
bleed em again! RP, RD, P, D, farthest from the master cylinder to the closest to the master cylinder, when you bleed em see if the cold rotor side bleeds as well as the others, my guess its either air, bad lines, or a jacked up caliper. when u bleed just let the pedal go halfway to the floor, not all the way. good luck, hope it helps!
Old Aug 17, 2009 | 08:27 PM
pigmak's Avatar
Default ok, thanks
maybe my pads are in rough too? My other caliper issue is fixed. Two new calipers. Both lines to the back have flow. I bled rears and both had fluid. I did not do the front, must I? Is this what is the problem?
Old Aug 17, 2009 | 08:46 PM
you need to bleed them all, and if you did recent work on them (as it sounds you did) you may want to bleed quite a bit to make sure your getting all the air out of all the lines. also keep your MC topped off so you dont get air in it.
96realwe
Dec 10, 2010 09:19 AM
JTalley
Nov 29, 2010 12:10 AM
Oldbowtie
Feb 14, 2009 09:58 AM
MemphisBlazer99
Dec 28, 2008 11:00 PM
thegr81
Oct 19, 2007 08:18 PM
