No communication from ATC module
Old Feb 6, 2025 | 03:23 AM
Mr2000Bravada's Avatar
Mr2000Bravada is on a distinguished road
Default No communication from ATC module
I have a 2000 Olds Bravada. Tech2 says lost communication with ATC module. What's the process to get that module back on the network
Old Feb 6, 2025 | 01:18 PM
GeorgeLG's Avatar
The most likely causes are:
  1. The module is dead
  2. Power/ground problems to the module
  3. Issue on the class 2 serial data line(s)
Step one is check the power and ground to the module. Step 2 is remove the comb from the class 2 bus connector and look on that modules data line to see if there is any traffic. If not then look at that data line near the module to see if that data line has issues.
Attached is the data line schematic. Let me know if you need any further help.
George
File Type: pdf
Old Feb 8, 2025 | 04:16 AM
Thanks a ton George. I will test it out this weekend. Let you know what I find.
aloha
Mar 1, 2022 02:02 PM
IanD
Nov 21, 2012 06:06 PM
ajcwf9
Dec 23, 2010 08:20 PM
nTro
Feb 5, 2010 09:40 PM
