No engaging from 4WD, how to start root cause analyses
Old Aug 5, 2010 | 08:42 AM
monette999's Avatar
monette999 is on a distinguished road
Default No engaging from 4WD, how to start root cause analyses
my name is Bob and I am driving an S10 Blazer in Germany and to be hownest this is a rare vehicle which almost gets no service. Specially on 4wd.
The problem I have is that when I drive in 4WD low or high the system won´t release it back into 2 WD mode. I tested it twice and got lucky the it somehow returned back into 2wd.
My system has a black vacumn tank on the driver side. I assume to have a VCP valve behind the dizzy. Hanve not found yet.
I have the square buttons which allows me to choose the driving mode 2wd 4wd high 4wd low.
If the system won´t allow to disgage then I assume to look on the valve to see it it get a signal for a machanical activity. How would you start simulating this problem in a static condition.
BR
Bob
File Type: pdf
File Type: pdf
Old Aug 5, 2010 | 10:30 AM
pj5454302's Avatar
I am guessing that you have a st gen pre 95 and its probobly your front diff actuator. ITs located under your batery tray. They are known to go out.
seriosbrad
Nov 7, 2015 09:08 PM
trad444
Sep 27, 2014 10:22 PM
pfsantos
Sep 23, 2010 12:04 PM
zombiebebop
Engine & Internal
Dec 8, 2006 03:15 PM
Jeremy_87_S10
May 22, 2006 10:16 PM
