No Floor Heat
It is winter now and i am forced to drive with cold feet. An old post on the site talks about repairing the gate door within the ducting by cutting a hole, finding a broken vacuum actuated gate door or axle and fixing and then patching the access hole afterwords. Not doing this means tearing the whole dash apart. Someone was going to post photos of where the hole was cut but never did. Someone used a mirror successfully to see what was going on. I need more info on this problem on my 98 blazer.
Thanks.
Thanks.
coathanger heater floor site:blazerforum.com
gets you
https://blazerforum.com/forum/showthread.php?p=479880
gets you
When I close the vents individually there's enough air leaking through the defrost to safely drive, but that's as far as I got
