No Heat but blower works
Old Nov 3, 2009 | 09:03 AM
Rhodes19's Avatar
Rhodes19 is on a distinguished road
Default No Heat but blower works
Hi All,
My daughter's 99' Blazer is not producing heat for the heater or defroster. The blower fan works and the mode selector switch seems to work as well. What should I check for and how would I fix it. Thanks for the help.
Old Nov 3, 2009 | 09:34 AM
Check to see if both of the heater core lines under the hood are the same temperature once the engine is up to operating temp. If they are not, then you have a restricted core.
Old Nov 3, 2009 | 09:45 AM
Rhodes19's Avatar
Hi swartlkk,
Thanks for your help. I will check it tonight when I get home.
Old Nov 6, 2009 | 11:30 AM
lgual's Avatar
lgual is an unknown quantity at this point
Default No heat
Hi,
I am having the same problem with my 99 blazer. Both heater lines remain cool with the engine warm. Blower works too. Seems as though I have a restricted heater core. How do I resolve this? I hope I don't have to get to the heater core as that seems like a project, removing the dash and all.
Thanks,
Larry
Old Nov 6, 2009 | 11:33 AM
The first thing is to attempt to flush the core.
Old Nov 6, 2009 | 04:17 PM
blackjimmy's Avatar
blackjimmy is on a distinguished road
I had a problem with my jimmy a couple of years ago,same symptoms as yours. I put a flush adapter on a heater hose didn,t work. so i held a garden hose on the heater core fitting ,and a big blob of slime came out of it, it has worked great ever since.
Old Nov 17, 2009 | 01:05 PM
Rhodes19's Avatar
Well, my daughter came home long enough so I could work on her vehicle. It turns out it was about 1/2-2/3 gallon short of radiator fluid. Topped it off and it works fine now. Seriously considering flushing the system any way to be on the safe side.
Old Nov 17, 2009 | 01:34 PM
Now you have to determine the cause of it being low. I would replace the cap as a first precaution.
Old Nov 17, 2009 | 04:56 PM
blazer blaze13's Avatar
blazer blaze13 is an unknown quantity at this point
pressure test the cooling system to check for leaks as well
Old Nov 19, 2009 | 08:04 AM
Rhodes19's Avatar
Thanks swartlkk and blazer blaze13. That will be on my list of chores for this weekend.
