no heat on floor
Old Dec 3, 2006 | 10:16 PM
chrissy's Avatar
chrissy is an unknown quantity at this point
Default no heat on floor
i have a 99 zr2 and the heat works great but it wont go to the floor what would cause this
i looked behind the glove box and the and that seeems to be moving fine . what else could be the pro blem
thanks for the help guys
Old Dec 3, 2006 | 10:47 PM
Default RE: no heat on floor
So when you change the modes (defrost, vent, etc..) it will go, but when you put it in the floor it doesn't work? If that is the case, then you may have a bad vacuum actuator for the floor blend door.
If it only comes out through the defrost, you most likely have a vacuum supply problem to the HVAC control head.
Old Dec 3, 2006 | 10:59 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
I noticed for my blazer that if I am going from the face vents (vents on the dash) to the floor it takes about 15-20 seconds for to fully change over.
Old Dec 3, 2006 | 11:02 PM
Chris in NY's Avatar
Chris in NY is an unknown quantity at this point
My bet is the floor blend door is broken. The arm snaps off of the door itself. On a '99 Blazer, you can check this by removing the plastic panel that contains the 12V outlets and then sticking your head up into the dash over by the throttle pedal. If you look up in there (again on the driver's side) you can see a white arm sticking out of the HVAC module with a torsion spring on it. Then there's a rod going down to the vacuum actuator. If you start the truck up and turn the right side HVAC dial from vent to heat, you can see the vacuum actuator do its thing and then see if the arm rotates or just flops around.
The bad news is, as far as I know, you have to basically disassemble the vehicle to remove the HVAC module in order to replace this door. $15 part, but it's like finding a buried treasure to get at it.
Old Dec 4, 2006 | 03:23 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
chris in NY is right on on this one...I've changed at least 15 of these for this concern.
TheJuicer
121
Oct 26, 2017 07:39 PM
reed2003
Jun 16, 2011 07:15 PM
jetrider
Feb 20, 2008 10:35 PM
new67rs
Feb 21, 2007 10:56 AM
guywm25
Oct 11, 2006 10:14 AM
