No heat! I'm puzzled.
Old Mar 9, 2013 | 06:16 PM
swanman35's Avatar
swanman35 is on a distinguished road
Yeah, I guess errativ oil gauges are common. And yeah, I mine all have to do as well
Old Mar 10, 2013 | 09:40 AM
Charles Hines's Avatar
Charles Hines is on a distinguished road
Blend door actuator comes to mind.
Old Mar 15, 2013 | 05:49 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
Well guys & gals my heat works again!!! I ran some rad. flush stuff thru it last night for about a half an hour then dumped it & flushed the heater core out w/ the garden hose until I got clear water & ran clean water thru the whole sys acouple of time by filling the cooling sys. running it & dumping it (rinse & repeat) a couple of times & then filled it back up w/ coolant & water & now she'll cook ya out of the truck. I even checked the ac sense its getting warm & that works to so I'm happy again. No more cold 45min drives in to work at 5am.
Old Mar 15, 2013 | 09:45 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
Thumbs up no heat easy fix
does the blower motor work? if not replace it takes 15 mins 3 bolts to undo
under passenger side of dash.. if the blower works drain the rad add some CLR
into the hose coming out of firewall add enough that it trickles out let sit for 15 mins flush with water then blow some air through amazing how much crud will come out .. refill rad with coolant mixture and you will have heat like it is a new unit
Old Mar 16, 2013 | 12:44 AM
Irocz327's Avatar
mike- i wish i would'a known I could use clr have some under the sink. but like my post above yours said. I put some rad flush from orileys threw it & flushed the heater core w/ a garden hose & now she works like a champ.
camaross0110
Lowering Tech
Nov 1, 2010 04:48 PM
89GMCJames
Dec 2, 2009 07:29 AM
taloka
15
Nov 9, 2009 09:18 AM
jman_08
Nov 7, 2008 12:38 PM
kingdog
Aug 25, 2008 03:51 PM
