No heater
Old Oct 27, 2007 | 02:09 PM
jus1087's Avatar
jus1087 is an unknown quantity at this point
Default No heater
My heater was working one day and then it just quit working on me. When I turn the control to heat it sounds like its going to blow heat out but never does. Also my a/c control with the defrost and vent adjustments doesn't work at all it can only turn my air on and off and nothing else. If there is anyone who can help me please let me know. Thanks
Old Oct 27, 2007 | 03:51 PM
Blazer_boy's Avatar
Blazer_boy is an unknown quantity at this point
Default RE: No heater
Id check to see what your antifreeze level is. I had a similar problem. I head a leaking heater core wich im in the midst of replacing
Old Oct 27, 2007 | 06:30 PM
If you can not change the mode (defrost, floor, front panel, bi-level), then I'm betting that the vacuum source to the HVAC control head has either been disconnected or otherwise interupted.
Is this a 4wd truck?
Old Oct 27, 2007 | 06:34 PM
jus1087's Avatar
No its a 2000 2wd s-10 blazer.
Old Oct 27, 2007 | 07:01 PM
That simplifies things a bit more.
There is a vacuum reservoir in the driver's side fender that stores vacuum pressure for the HVAC system. I would make sure that the vacuum supply is still connected to the engine. Follow the hoses from the res to the engine as well as what goes into the firewall to the HVAC control head in the dash.
Old Oct 28, 2007 | 07:12 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
what about the blower motor? i have the same problem in my truck and what ive been hearing is the blower motor died.
Maulsmasher
14
Dec 16, 2009 09:01 PM
Blue Vette
Nov 14, 2005 02:31 AM
Silverfox
Mar 15, 2005 02:51 PM
jimmyone
Jan 27, 2005 06:32 PM
dawne fischer
Dec 21, 2004 12:16 AM
