No power in 4th gear
Old Dec 4, 2011 | 01:28 AM
318bruiser's Avatar
318bruiser is on a distinguished road
Default No power in 4th gear
Everything is fine until I hit 4th gear on the interstate around 60+mph. Then it has no power to even stay at a constant speed. It will either downshift or I have to push the accelerator farther to just stay at a constant speed. I also only get about 12mpg highway. No codes are being thrown except the normal 12.
1992 S10 Blazer, 4x4, 4.3, 4sp auto, 31x10.5x15 tires.
Things I have done.
Oil change and tune up, except the timing. Doing that tomorrow.
Headers + new exhaust W/O cat.
Rebuilt TBI, new fuel pump -fuel pressure is good.
Ignition coil, MAP, O2 Sensor,temp sensor.
The transmission seems smooth except 1-2nd gear hits a tad hard. I also need a accelerator cable, mine is cracked. The only one I can find is a "pioneer" 31.5" long at Orielly's but the attachment isn't right. I any one has any suggestions I am all ears and TY in advance.
Old Dec 4, 2011 | 09:51 AM
ChevyBlazerChick's Avatar
Hmmm. I think the Accelerator Cable may be the reason here. When you say cracked... what exactly do you mean? just the plastic sheath? Or the plastic that keeps it from slipping out of the bracket?
Old Dec 4, 2011 | 02:36 PM
318bruiser's Avatar
The plastic sheath that meets the piece that goes into the bracket is completely cracked 360 degrees so it makes no contact with that piece.
greenhornet
Apr 28, 2012 07:28 PM
chevy4ever
Oct 6, 2010 10:49 AM
HectorR2006
Jun 29, 2010 11:11 AM
1blkblazer422
May 3, 2009 07:31 PM
Swblazer
Nov 14, 2007 07:43 PM
