No Power After Starting
Old Jul 5, 2009 | 04:09 PM
cameraman12's Avatar
cameraman12 is on a distinguished road
Default No Power After Starting
I have a 99 4x4 4 door blazer. In the most of the time when i start it, the truck just won't go. There is no power, i have to drive half a mile or so before it will power will kick in. I can step on the gas the the rpm will go up but the it just won't go. A friend of mine said it could be a seal leaking, and until enough pressure if built up it wont go. Another guy say it could be the vacuum pump going. Took it to the shop they don't know what wrong with it. Anyone on here every experience anything like that? IF so any advice on how to fix it?
Old Jul 5, 2009 | 04:36 PM
rriddle3's Avatar
I moved this thread to the '2nd Gen Tech' so you may get some help faster. I also changed the title from 'help', which really does not tell enough to attract attention to your problem.
Old Jul 5, 2009 | 06:38 PM
Sounds as though you have a transmission problem. I had a Dodge Ram pickup that had a problem after it would set for a few days. It was a check valve that was not sealing up properly allowing the torque converter to drain out. It would take an easy 60 to 90 seconds before it would even move.
I would take it to a transmission shop for diagnosis. If you still do not have an answer, then you may want to try some Lucas Transfix. I am not an advocate for the miracle in a bottle type products, but Lucas Transfix cleaned up the sticking check valve in the transmission of my old Ram.
Old Jul 6, 2009 | 11:19 AM
bandidolenny's Avatar
Yes, it does sounds like a transmission problem from what you are describing. Possibly slipping, possibly losing the tranny pump or a cracked or broken sun gear.
You need to find a shop that has a clue...
TigaHotty85
Jun 17, 2013 03:10 PM
cgrett
Nov 15, 2010 09:08 PM
zrider79
Oct 15, 2010 09:55 AM
Sprocket
Mar 20, 2008 09:39 PM
richard5294589
Dec 23, 2006 01:03 AM
