No power to icm or ignition coil
Old Oct 1, 2013 | 07:14 PM
billyboy2287's Avatar
billyboy2287 is on a distinguished road
Default No power to icm or ignition coil
Here is what is gathered so far. 97 blazer 4x4 4.3 no spark.no power to icm or coil...
Ignition coil:
Terminal A, PNK wire, ignition voltage, from 20A ECM/Ign fuse 10 in I/P fuse block
Terminal B, WHT wire, tach sig, to IPC terminal 8
Terminal C, WHT/BLK wire, tach sig, from ICM terminal D
ICM:
Terminal B, WHT wire, ignition timing sig, from VCM connector C3, terminal 9
Terminal C, BLK/WHT wire, ground
Terminal D, WHT/BLK wire, tach sig, to ignition coil terminal C
Upstream of the ECM/Ign fuse is the ignition switch and then one of the fusible links.
Ignition coil:
Terminal A, PNK wire, ignition voltage, from 15A ECM1 fuse in underhood fuse block
ICM:
One says its under the hood in the fuse block the other says in the truck. Where is the fuse block under the hood? And all the fuses in the truck checked out. I need to trace it all the way back im guessing it could either be a bad wire, fuse,ecm or ignition switch. is this a common problem on these trucks what would you guys think it is?
jkyle187
Feb 15, 2015 08:45 PM
brain7734
Sep 29, 2013 01:27 PM
Lancealot
Feb 22, 2011 07:34 AM
cannibal440
Performance & Brainstorming
Mar 18, 2008 10:47 AM
USMaverick101
Oct 31, 2006 03:10 AM
