No response from automatic temperature control
Has anyone gotten no response from their automatic temperature control head? I have no fan, temp, or air-directional control. The only thing it will do is light up when the parking lights are turned on. I checked the HVAC fuse under the hood and the HVAC 1 fuse in the interior box and they are good and have a good power feed to the fuses.
You didn't provide any vehicle data... But when I parted out a 96 I took that unit and put it in my stock,as I replaced that car with a 97. Glad I did because that module failed the same way you describe and I had one on hand. That is most likely the issue you are dealing with,as it is only a plastic electro/vacuum switch and prone to age related failure.
Sorry about the vehicle data... I have a 2000 LT 4x4 with the 4.3 V6. So you just replaced the control head? Did you hear a hissing noise from under the dash before the control head went out?
JapsMcGee
Jun 26, 2014 03:38 PM
RedBlazer 96
32
Jan 29, 2013 01:30 PM
Grinch 85K5
Nov 25, 2009 07:36 PM
