no sound coming out
Old 01-15-2008 | 03:50 PM
imaracer's Avatar
imaracer is an unknown quantity at this point
Default no sound coming out
hey everyone...i had taken my car into the dealer to have the heater core replaced and when i got it back my stereo wouldn't work. it powers up and carrys out any task, but no sound will come out. i then threw the stock one in real quick to see if it was bc of my head unit and no sound came out of that either. does anyone know of something that will cause these problems?
Old 01-15-2008 | 04:01 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
Default RE: no sound coming out
do you have a sound system in your truck? if you do check the fuse to the goods. if not, it sounds like there may be some wires that were cut off of your stereo harness. idk though, just the first things that came to mind.
Old 01-15-2008 | 04:25 PM
imaracer's Avatar
well no stereo system...alpine head unit and jl speakers no amp
Old 01-16-2008 | 08:26 PM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
How about the wires? Have you checked them to make sure that none of them got nicked or anything?
Old 01-16-2008 | 09:00 PM
hillbillyinOhio's Avatar
pop your radio out and strip out part of all of the speaker wires. Take a AA battery and touch the pos wire to the pos side and neg to negative. My guess is a wire is grounding out.
Old 01-17-2008 | 01:37 AM
imaracer's Avatar
when i connect the speaker wires to pos and neg what am i looking for?
if something was nicked would the stereo power up and no sound come from any speaker?
Old 01-17-2008 | 03:29 AM
blzR's Avatar
blzR is an unknown quantity at this point
Sure sounds as though mr.heatercoremechanic pinched or cut some wires that run close to speaker wires.Are you absolutly positive you plugged all (3 i think) wire blocks into & correctly intostereo behind dash?
Old 01-17-2008 | 08:30 AM
imaracer's Avatar
yes i am i have had this radio out 100 times probably since owning it
Old 01-17-2008 | 09:31 AM
sory bout omitting that. each speaker will pop when you put the battery to the wires. that way you can tell if one is blown or since they were all working, which speaker is the culpit.
Old 01-18-2008 | 10:07 AM
blzR's Avatar
wow! you must have broken your hazard switch at least once right?!
Quick Reply: no sound coming out
